February 02, 2026, 11:09:37 PM *
Author Topic: starter button repair  (Read 1601 times)
bg
Cumming, Ga
« on: July 25, 2011, 07:47:33 AM »
i just read the shoptalk article on the starter button repair.
for me, none of the blue hot links containing pics worked.
i was getting a 404 error or something like that.
anyone know of another write up with pics i could look at.
« Reply #1 on: July 25, 2011, 08:02:45 AM »
There are good pictures on some of the most recent threads regarding this exact subject.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: July 25, 2011, 01:45:41 PM »
...and it is REAL easy if you are slow and careful.
CASABROKER
« Reply #3 on: July 25, 2011, 02:05:28 PM »
I just had this issue 1200 mi from home.  I am assuming you get nothing when the stater button is pushed and the headlight won't come on.  Take the switch out of the handlebar casing.  Spread the plastic switch apart and pop the black top off.  Clean all the contact points.  I had to bend the 2 small contacts on the bottom white part slightly up to get a solid contact.  You can check it without putting it all back together in the handlebar.  Just make sure you get contact with the 2 small contacts on the bottom white part of the switch.
RonW
Newport Beach
« Reply #4 on: July 25, 2011, 03:34:38 PM »
Are you done yet?
recent discussion
rattlebars
Most of it involves removing and reinstalling 4 screws on the left side handlebar housing [edit] RIGHT HOUSING. 2 external, 2 internal. They may or may not be a source of frustration. Don't misplace nor drop the 2 little internal screws. I guess you could screw them back in place temporarily to keep track of them. And you don't use a micro precision phillips screwdriver on those because the "X" on the head is larger than it looks.
« Last Edit: July 25, 2011, 04:22:30 PM by RONW » Logged
2000 Valkyrie Tourer
bigguy
VRCC# 30728
Texarkana, TX
« Reply #5 on: July 25, 2011, 03:47:18 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,30893.0.html
Here you go.
Here there be Dragons.
