January 28, 2026, 06:26:45 PM *
Author Topic: Starter button  (Read 2289 times)
Merle
« on: May 24, 2009, 02:47:50 PM »
After several cleanings of my starter button I just want to replace the whole assembly.  Where is the starter switch assembly wire connection.  I was going to order another switch but was looking at the wires and can’t see the connection point?  Is it a difficult fix? I know it was just plug and play but can’t see where it hooks up.  Do I need to take the tank off?
junior
new hampshire
« Reply #1 on: May 24, 2009, 03:01:19 PM »
no you dont have to take the tank off and it is an assy the killswitch starter button and the 2 halfs that clamp to the bar is all one peice
Duey
Rochester, MN
« Reply #2 on: May 25, 2009, 12:49:11 PM »
As mentioned - you have to buy the entire assembly. Both halves of the housing and all the switches. $$$$$ They don't sell just the switch. Maybe someone knows where to get it aftermarket. Good Luck!
Kingbee
VRCC# 576
Northern Illinois
« Reply #3 on: May 25, 2009, 07:01:51 PM »
What he wants to know is, Where do the wires that come with the switch assembly plug in, in a Tourer. Headlight?  Neck? etc.
1999 Interstate
2000 Interstate
2004 Rune
RP#62
Gilbert, AZ
« Reply #4 on: May 25, 2009, 08:44:21 PM »
Headlight shell.
-RP
« Reply #5 on: May 26, 2009, 07:58:31 AM »
Refer to the link on how to install a relay to take the high amp load off that starter/headlight circuit. That seems to be the major cause of eventual failure of the little slider switch contacts. When I did it on mine, I simply mounted the relay inside the headlight bucket, bolted it down with one of the three bucket mounting bolts. At the time I first did the change I figured out the difference in amperage but it seems like it dropped the amps carried by the starter button contacts from around 3-4 amps to less than 1. Someone can correct me on that, just going by memory but it is a substantial drop.
http://www.rattlebars.com/mtz/starter.html
