February 05, 2026, 06:24:13 AM *
Author Topic: Recommended Grease?  (Read 3182 times)
BIG--T
The Twilight Zone
« on: June 14, 2012, 09:08:38 AM »
I am putting on a new rear tire and wonder what the best grease to use for the flange and bearings?
Moly paste , Belray?
Thanks   Smiley
« Reply #1 on: June 14, 2012, 09:15:51 AM »
I use a waterproof front wheel bearing grease.
I buy it at almost any Auto Parts store.
Since we do most of our parts business with O'Rielly, that is where mine came from.
BIG--T
The Twilight Zone
« Reply #2 on: June 14, 2012, 09:22:12 AM »
Thanks RJ just saved me a trip to the bike shop.  :cooldude:o
9Ball
« Reply #3 on: June 14, 2012, 10:29:14 AM »
for the driven flange you want moly paste, not grease.  If unsure whether it calls for grease or paste refer to the service manual.  These really can't be used indiscriminately.
The advice you got above was ok for the front wheel and bearings but not the final drive flange.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
BIG--T
The Twilight Zone
« Reply #4 on: June 14, 2012, 11:04:01 AM »
Thanks, I don't have a shop manual but heard about the moly paste.
« Reply #5 on: June 14, 2012, 11:12:01 AM »
I ain't getting in a pissing match with ya, but that is all MGM has had for 242K miles.    Still original rear end.
As Forrest Gump would say:
“That's all I have to say about that.”
NITRO
Eau Claire, WI
« Reply #6 on: June 14, 2012, 11:20:20 AM »
Same here, just grease and all has gone well for me. I use Green Grease.
When in doubt, ride.
BIG--T
The Twilight Zone
« Reply #7 on: June 14, 2012, 11:20:44 AM »
242,000?  That's good enough fer me!  cooldude
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #8 on: June 14, 2012, 11:47:01 AM »
i use belray waterproof grease, but any grease will do just fine.  there are alot of people here who use just plain old axle grease, and it does a great job.  the moly 60 paste tends to dry out and crack after awhile.  listen to mgm...HE'S RIGHT ON !!!!
JaysGone
Delray Beach Florida
« Reply #9 on: June 14, 2012, 09:02:16 PM »
Water resistant green or marine bearing grease for me too.
Never been an isssue.......
Plenty of moly in most greases made these days.
      1999 Valk - SOLD
      2005 Yamaha RoadStar
whitestroke
San Pedro, Ca.
« Reply #10 on: June 14, 2012, 09:41:47 PM »
Not sure if you can get to the wheel bearings, mine were sealed and also had an exterior seal.  I did nothing with the bearings, except to check for smoothness and no slop.
If you've got the time why not order the Moly Paste/Grease what Honda recommends.  I used Guard Dog 525 .  Do not mix greases, clean well before you ad fresh grease
While your in there it's only 15 more minutes to (service axle) I mean drive shaft, a must do....
« Last Edit: June 15, 2012, 09:50:24 AM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
9Ball
« Reply #11 on: June 15, 2012, 02:45:24 AM »
While your in there it's only 15 more minutes to service axle, a must do....
best advice I've read so far...
I'll give you my opinion, since some of the other's are rabidly advocating only grease.
You will find lots of threads on destroyed final drive units.  You will also find many threads here on what grease works best and why.  If it was my bike (and I use this advice, so it's relevant here), I follow the Honda Service Manual's instructions for my maintenance.  If it says grease, I use grease (the brand doesn't matter...the rating for the grease does).  If it says locktite, I use locktite.  The moly paste the manual recommends has a minimum moly spec, so any moly paste that meets the spec will do.  Choose your own brand...there are some good ones out there.
You'll see a lot of "I've been doing this for xxx,xxx,xxx,xxx miles, so it must be OK. Who ARE you to recommend "xyz" that Mother Honda specifies?"  (Just an exaggeration, but you can get my drift).  That's your choice to listen, or not.
If you are a high mileage rider, like some of the recommendations suggest, then these same riders are replacing tires multiple times in a season, are always servicing their final drives, and could probably use olive oil and get the same results (just kidding, but you get my point).
If you are not a high mileage rider and it takes several or more years to wear out a rear tire (like the car tire guys or us lesser riders), then grease alone may not be your best choice.  Again, your decision to listen or not.
I'll stick with recommending what the manual calls for.  I don't have the super-high mileage credentials to throw at you, but I have been a member here for over 12 years and have seen a lot, good and bad.
This is my opinion and one "I" feel best making to a fellow VRCC member.
Good luck...
« Last Edit: June 15, 2012, 03:50:16 AM by jrhorton » Logged
1999 Standard
2007 Rocket 3
2005 VTX 1300S
9Ball
« Reply #12 on: June 15, 2012, 02:51:46 AM »
BTW, There's a shop manual online at Dag of Norway's website.
http://valkyrienorway.com/Tech%20tips%20(links).html
select the flashing red button for the manual download.
« Last Edit: June 15, 2012, 03:03:33 AM by jrhorton » Logged
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #13 on: June 15, 2012, 03:15:46 AM »
This is a sticky subject...good advice from jr Horton, can't refute RJ's personal experience either.
  You will find as many opinions as riders here. I have tried both. Personal experience from me, the Moly is always dried up when I check it. I have switched to Bel-Ray Waterproof grease on everything on my Valk. I have no problems and the splines are always nice and fresh looking.
  My local dealer doesn't even carry moly paste anymore, they use the Bel-Ray. After finding that out, it was easier for me to switch.
This will boil down to research for you and a personal decision.
Please don't ask about OIL Grin
9Ball
« Reply #14 on: June 15, 2012, 03:51:53 AM »
or tires, or octane....
We don't have too many local Honda dealers around here either, and their stock is often limited.  I now buy the Moly paste online when I buy other parts....here's a link.
http://www.directlineparts.com/product.asp?pid=4330&str=2
It's actually funny that on the Triumph Rocket forums there have been lots of discussions regarding final drive failures and lack of service for the driven flange by the Triumph dealers and tire-changer shops.  Many of the DIY guys have found that the Honda Moly 60 is a good product for the Rocket final drive and it is often recommended (not by me either).  The Triumph service manual doesn't even mention lubricants for this critical item....and the R3 final drive is over $2200 to replace.
« Last Edit: June 15, 2012, 03:58:17 AM by jrhorton » Logged
1999 Standard
2007 Rocket 3
2005 VTX 1300S
BIG--T
The Twilight Zone
« Reply #15 on: June 15, 2012, 04:37:09 AM »
Thanks jrhorton, Tundra, and all the people that responded.
Yes i just asked a very stupid question that I deleted!  Embarrassed  Yes I will order the parts and just not ride until i get it done!  Cry
Thanks jrhorton for that manual, that's just what I needed!   cooldude
« Last Edit: June 15, 2012, 05:35:29 AM by BIG--T » Logged
« Reply #16 on: June 15, 2012, 04:46:01 AM »
The way that molybdenum lubricates is by metal-on-metal...
If you look at the moly-paste ads that are targeted to industry, they go
on and on about stuff like:
     Pressure and friction actually burnish the Molybdenum into the metal offering excellent
     resistance to high pressure and heat.
    a soft paste with a high Molybdenum disulphide content which bonds to metal surfaces
     providing long term dry film lubrication.
I think the "paste" part of moly-paste is just a carrier that allows us to
smear it around easily.
BIG--T
The Twilight Zone
« Reply #17 on: June 15, 2012, 05:06:19 AM »
I also found on another forum  Moly is also that way so it it doesn't sling out on your wheel. I wouldn't know since i haven't used it yet.  Undecided
BIG--T
The Twilight Zone
« Reply #18 on: June 15, 2012, 05:29:03 AM »
Is there something wrong with that link? I downloaded it twice and it says it can't open it, it's "like an email".?? I downloaded the latest version of Adobe and no go. Any ideas? I need that manual bad!  Thanks
« Reply #19 on: June 15, 2012, 06:50:09 AM »
Maybe try:  http://www.valkyrienorway.com/download.html
Expect to wait a while with dial-up, but the manual you can get from there is just what you need...
http://www.valkyrienorway.com has some links you could read, removing the rear wheel is one of them...
BIG--T
The Twilight Zone
« Reply #20 on: June 15, 2012, 08:14:09 AM »
Mike, I've tried those links without success. Here's what it tells me after the download:
" Adobe reader could not open because it is either not a supported file type or because the file has been damaged( for example, it was sent as an email attatchment and wasn't correctly decoded."
BIG--T
The Twilight Zone
« Reply #21 on: June 15, 2012, 10:24:33 AM »
you might need a newer version of the adobe reader...I believe it is very large file and may be a problem to attach to an email.
Yes, I downloaded the latest version and nada!
Blackduck
West Australia
« Reply #22 on: June 15, 2012, 08:01:42 PM »
Another good product is Castrol LMM grease. Used for Constant velocity joints in Front wheel drive cars. The only time they get a re-grease is if a boot tears and they last a long time.
Cheers Steve
judd
VRCC# 13453
B.C. Canada
« Reply #23 on: June 16, 2012, 08:37:03 AM »
Thanks   Smiley
Check this recent post, http://www.valkyrieforum.com/bbs/index.php/topic,42372.0.html
 ..............I use and recommend  Loctite Moly Paste 51048. It is designed to work under High heat and extreme clamping pressures where ordinary grease will simply be squeezed out leaving little or no lubrication.
I changed to this because on my first tire change I found the original Honda Moly paste dried up and rust colored, The Loctite product remains the same as the day I put it on and the splines are as new.
Product data from their site......... http://www.rshughes.com/images/products/docs/lq46oQvztkLKlcj2CzmnLA.pdf
F6MoRider
Lakeland, FL
« Reply #24 on: June 16, 2012, 12:59:36 PM »
Other than to say follow the manufacturer's recommendations, i won't wade into the moly no grease issue.  I do what he folks who built it say to do.
One major component of rear end maintenance that affects the grease are those 3 little o-rings that seal water out and lubricant in.  Get the replacements from Carolina trike at a cheap price and in a quantity that makes it easy to change them each time you remove the rear end.  Store them between changes so they don't deteriorate.
If you can keep water out and lube in, it will prevent a number of issues and go a gazillion miles.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
lifguardct
2000 Interstate, 2009 Stratoliner (2007 ZX14 sold)
Southwest Florida
« Reply #25 on: June 16, 2012, 04:14:36 PM »
Thanks, this looks like a better deal than Honda...
http://www.carolinabikeandtrike.com/ORings.htm
