February 05, 2026, 09:18:27 PM
Question re. the forks.
Topic: Question re. the forks. (Read 1482 times)
October 03, 2012, 01:46:55 PM »
On some bikes the lower section(part the axle runs through) is screwed on the lower tube. Is that how it's done on the Valk? I've never had to address this in the past but contemplating some additional chrome in front and not sure that part is included.
dalai-lama
Wish I was out riding...
Watertown CT
Checkout this post
October 03, 2012, 05:12:19 PM »
Karen Brooks asked me see if I could give you a hand. I remembered seeing a post a while back about being able to unscrew the fork tube.
Here is a link
http://www.valkyrieforum.com/bbs/index.php/topic,34094.0.html
Hope this helps
the dalai
the dalai
YoungPUP
Valparaiso, In
Re: Question re. the forks.
October 03, 2012, 05:12:32 PM »
Here's a link to a thread of mine from about a month-ish ago. I had to ask this same question due to some nasty rock damage to my right slider. They are threaded on, and was told a GOOD heat gun aids in removal.
http://www.valkyrieforum.com/bbs/index.php/topic,46851.msg446505.html#msg446505
99 STD (Under construction)
Thanks guys.
October 03, 2012, 07:39:31 PM »
That told me what I needed to know. Now I'm wondering about that lower piece....should I chrome it or polish it? I currently have one of those chrome covers mounted over them and they look OK. Maybe a good polishing is all that's needed in that case.
Grumpy
Tampa, Fl
October 03, 2012, 09:02:23 PM »
I can polish them for you, I think we misunderstood each other the other day, The chrome ones that I have seen from mike are the upper tubes, and the lower ends. All the guts from your forks need to go in the new ones.
YoungPUP
Valparaiso, In
October 04, 2012, 05:58:28 PM »
IMHO polishing versus chroming would be a pretty easy decision to solve. Which holds up better in the salty Florida air?
