February 06, 2026, 09:34:56 AM *
Author Topic: USB port.  (Read 2162 times)
YoungPUP
Valparaiso, In
« on: December 23, 2012, 05:40:20 PM »
I'd like to add a Usb port to the Valk and the Subaru for charging the Ipod thingy. Would like something I can hardwire in, but don't know much about the USB thingy other that its built into the side of my computer.
99 STD (Under construction)
Westsider
Fort Worth TX.
« Reply #1 on: December 23, 2012, 05:44:56 PM »
Hey , You can get a 12v usb adaptor for cig lighters outlet, mutipul usb in fact. Ebayem. Merry Christmas. cooldude
« Reply #2 on: December 23, 2012, 05:46:40 PM »
Go to any major truckstop they have them hangin' thats plug and play  cooldude
mmurffy03
03 standard
toms river new jersey
« Reply #3 on: December 23, 2012, 06:00:18 PM »
home depot has them with either 1 or 2 usb imports that plug into my handlebar mounted cig lighter to charge my ipod phone and GPS but only 2 at a time  i thenk it was about 15 bucks
PhredValk
Edmonton, Alberta, Canada
« Reply #4 on: December 23, 2012, 06:20:53 PM »
Connect one to a relay from a fused wire from the battery triggered by the AUX wire. I have three USB ports, a power point and cig lighter connected to a fuse panel under the seat that's powered that way. With several fuses available you can connect other stuff down the road; like a port to charge your cell phone, GPS, sound system...
Fred.
VRCCDS0237
Michvalk
Remus, Mi
« Reply #5 on: December 23, 2012, 06:35:47 PM »
My I/S had a cigar lighter in the pod, so I got a usb plug from Vreizon. Works good cooldude
Jeff K
« Reply #6 on: December 23, 2012, 06:45:13 PM »
Just be aware it will not run a garmin.
http://www.ebay.com/itm/12-Volt-Power-Point-with-5-volt-USB-Powerpoint-Outlet-/370409173256?pt=Car_Audio_Video&hash=item563e1b7108&vxp=mtr
PhredValk
« Reply #7 on: December 23, 2012, 07:15:00 PM »
Mine looks like that, but with two USB ports. One runs my Ipod and the other my Garmin Zumo 220. I cut the cig lighter part off and wired it to my fuse panel.
Fred.
VRCCDS0237
« Reply #8 on: December 23, 2012, 09:04:14 PM »
I just wrapped one up for my son-in-law for Christmas. It has 2 USB ports and can charge 2.1 amps. Another one on the rack had a single USB and was rated at 1 amp.
Colin
My old job
Orba, Spain
« Reply #9 on: December 23, 2012, 09:04:41 PM »
You may be able to find something like this your side of the pond but a bit spendy.
http://www.ebay.co.uk/itm/350632492009?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Colin
VRCC Espana
My Bumble Bee re-build
mmurffy03
03 standard
« Reply #10 on: December 23, 2012, 10:31:36 PM »
i have this one on my bars http://www.ebay.com/itm/Kuryakyn-Universal-Handlebar-Electrical-Power-Port-21300132-/170959651819?hash=item27cdfd43eb&item=170959651819&pt=Motorcycles_Parts_Accessories&vxp=mtr
DenverDave
Out past Mars ain't no speed limit -Mojo
« Reply #11 on: December 24, 2012, 06:47:04 AM »
http://www.kuryakyn.com/Products/4206/USB-Power-Source
I have had one on order since June, still waiting   Sad
Kind of pricey, but it supplies 2 amps, enough to charge an Ipad
Dave
1999 interstate green/silver
Denver, Colorado
VRCC#32819
VRCCDS#0238
JP in SC
Palmetto State Valk
New Prospect, Upstate SC
« Reply #12 on: December 24, 2012, 05:20:43 PM »
check this thread http://www.valkyrieforum.com/bbs/index.php/topic,44889.0.html from July. several sources are listed.
John
98 Standard - Black & Chrome
04 ST1300
YoungPUP
Valparaiso, In
« Reply #13 on: December 24, 2012, 06:02:41 PM »
THat burnsmoto one is exactly like what I was seeing in my head.  A little leary of buying electrical bits from some place called BURNS moto, but hey the Valks got full coverage.
« Reply #14 on: December 26, 2012, 09:06:45 AM »
I installed the Eklipes Cobra Chrome Motorcycle Power Adapter, it looks sharp and was cheap (have I ever mentioned I am cheap?).  It has an on/off switch with LED indicator, plus the standard cig lighter and also a USB power port.  It comes with a BMW jumper plug that handles over 2000 cranking amps for jump starting.  It can be had for around $30, check eBay.
« Reply #15 on: December 26, 2012, 09:11:41 AM »
here it is
PhredValk
« Reply #16 on: December 26, 2012, 09:36:55 AM »
Does that work as a cig lighter? I tried many 'power points' and none worked as a lighter. I finally got the Emgo lighter, weather resistant and big head for use wearing gloves.
http://www.motorcycle-superstore.com/3/14/141/20809/DPITEM/Cruiser-Motorcycle-Power-Accessories-Emgo-Handlebar-Mount-Cigarette-Lighter.aspx
I sealed the wiring in a pill bottle, siliconed to the bottom of the lighter and painted black.
Fred.
VRCCDS0237
« Reply #17 on: December 26, 2012, 09:48:38 AM »
Fred.
Nope, unfortunately the 12v plug only works for chargers and such, not lighters.  Still, it is a pretty nice unit, especially with the BMW jump adapter.
« Reply #18 on: January 14, 2013, 10:43:56 PM »
This is the one I was looking at installing.
http://www.cruisercustomizing.com/dual-usb-auxilary-socket-for-motorcycles/part/BBP-52-820
2 x 2.1amp outputs
There was also a mounting bracket available to mount onto the handle bars.
