February 06, 2026, 07:44:15 AM *
Author Topic: EBC Sintered Brake pads?  (Read 1476 times)
rccranger
« on: January 06, 2013, 08:55:13 AM »
I've read posts from various people stating that EBC Sintered brake pads are hard on OEM rotors. This statement is usually followed by "I've never used them, just OEM pads". I would like to hear from people who have used them and if they found they really did damage their rotors and how well they worked. I contacted EBC and they claim their pads are softer and put less wear on OEM rotors and they have not received any complaints from Valkyrie customers. Please do not respond with "I heard of a guy who used them". I would like to hear about first hand experiences. I have used EBC pads on all my previous bikes with complete satisfaction so I'm wondering why the Valk should be any different. Thanks guys.
« Reply #1 on: January 06, 2013, 09:50:20 AM »
If that is the way you feel then I suggest to just go ahead and use them.
With more "satisfaction"
Most all steel rotors are the same, not like stainless steel tho'
rccranger
« Reply #2 on: January 06, 2013, 10:18:18 AM »
Hi Ricky-D. I guess you miss-interpreted my question. I have no preference for EBC nor do I have a problem using OEM pads it's just that I've never seen a post from anyone with first hand knowledge of using EBC pads. The three local Honda dealerships here all recommend EBC and have to special order OEM and if you take it to their shop they normally install EBC's unless the customer insists on OEM. I don't want to have to replace my rotors later to save a few bucks on pads now but if there's no significant difference then it's easier and cheaper to buy EBC. For all I know Honda may farm out the production of their OEM pads to EBC, they certainly don't manufacture them themselves.
CoachDoc
San Diego, CA
« Reply #3 on: January 06, 2013, 02:23:14 PM »
I've used EBC pads on my Goldwing, and PO has them installed on the front wheel of my Valk. I've heard the comment about them chewing up OEM rotors frequently enough that I am convinced it is so. On my Wing I replaced the rotor on the rear wheel with an EBC rotor. If I had to do it again I would look for a used OEM rotor on eBay and stay with OEM pads. I don't like the noise with the EBC pads, and they are a bit 'grabby' for my liking.
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
« Reply #4 on: January 06, 2013, 02:26:22 PM »
see my post in this thread. People don't like EBC due to their braking torque curve which increases heat and wear, resulting in noisy squeel.
http://www.valkyrieforum.com/bbs/index.php/topic,13708.0.html
« Last Edit: January 06, 2013, 02:37:30 PM by CA » Logged
JC
The Beast
Franklin, TN
« Reply #5 on: January 06, 2013, 02:30:31 PM »
Made a significant buzzing noise when I used them, and for that reason I went back to OEM.
vanagon40
Greenwood, IN
« Reply #6 on: January 06, 2013, 02:33:16 PM »
rccranger,
Welcome to the forum.
Because you are new, I will give you this warning.  Brake pads probably rank third, behind oil brands and tire brands, as the most controversial topic on this forum.
Again, welcome.
1500Rider
« Reply #7 on: January 06, 2013, 04:01:44 PM »
Had them on my Valkyrie when I bought it. Impressive stopping power, however, I didn't care for the scraping sound they made so went back to OEM.
1990 Honda VFR750F
1997 Honda Valkyrie GL1500 Tourer
1998 Honda Gold Wing GL1500 SE
rccranger
« Reply #8 on: January 06, 2013, 04:06:29 PM »
Thanks for the input guys. I know, like oil and tires, it's a contentious issue. I think I'll take the advice given and order in some OEM pads. Thanks again.
Karen
Boston MA
« Reply #9 on: January 06, 2013, 07:16:09 PM »
EBC rotors with EBC Brake pads, Honda Rotors with Honda brake pads. I had EBCs put on my trike by a mechanic, who asked a Honda dealer what they'd use.  Rode with them a while, didn't like how they gripped, plus loud. Replaced them with the Hondas, and am happy again. The EBCs are quite a bit thicker than the Hondas, but they marked up my Honda rotors. May change to EBC rotors mext time around; have a friend who runs all EWBC and likes them very much.
larryh0841
« Reply #10 on: January 07, 2013, 06:51:42 AM »
I am the guy you are looking for.  I replaced my original worn out front brake pads with EBC pads, sold to me by my Honda dealer.  The result was ruined front rotors.  I then replaced the rotors with EBC rotors and new EBC pads and have never had a problem with wear on either rotors or pads.
        Larry
