February 06, 2026, 07:48:25 AM *
Author Topic: She just overheated (it's the Alt.)  (Read 4427 times)
SpidyJ
Murrells Inlet
« on: January 14, 2013, 05:06:50 AM »
.........pulling in the gate to work after the 12 mile drive. The light blinked a few times as I parked her then she stalled.
Fan does not run.
Now I worry all day. Guess I gotta call the wife to come pick me up so I can go home and get my trailer.
Dang it!!
« Last Edit: January 17, 2013, 04:46:57 AM by SpidyJ » Logged
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: January 14, 2013, 05:22:02 AM »
Sorry! Electrical? Keep us posted.  Undecided
My rides:
« Reply #2 on: January 14, 2013, 05:37:38 AM »
Simple stuff first. Is there enough coolant in the system? Let us know please. RIDE SAFE.
MP
North Dakota
« Reply #3 on: January 14, 2013, 05:46:45 AM »
Check coolant in radiator.  Sometimes it will NOT suck back from the bottle under the left side cover, and gradually gets lower.  Can be helped by bending down ears on rad cap.
MP
"Ridin' with Cycho"
« Reply #4 on: January 14, 2013, 06:39:57 AM »
Like said, checking the coolant at the radiator is the first place to look. Remember the set screw in the cap. Does the fan usually need to come on for this ride ? Did the engine actually get hot and make steam, or, did the light just flash on ? Depending on the year and model will determine how to diagnose the problem any further. Generally on the earlier models just grounding the radiator coolant temp switch will/should turn the fan on to determine whether the fan or the switch is defective.
SpidyJ
Murrells Inlet
« Reply #5 on: January 14, 2013, 06:52:29 AM »
It's a 99-IS.  The coolant is topped off and changed a year ago.  The overflow reservoir is right at the line.
No steam or smell even.  Light blinked two or three times as I parked it then it stalled.
The fan comes on in the Summer for sure during this ride. Not lately as it's been much cooler. IF the coolant gets hot the fan should come on right?  Why else would it overheat unless the pump stopped pumpin!
Peace,
johnnywebb
« Reply #6 on: January 14, 2013, 08:12:46 AM »
Did you "burp" it when you changed and top off the coolant? The stahl aspect of your ride is puzzling to me. Did the bike smell hot?
My rides:
SpidyJ
Murrells Inlet
« Reply #7 on: January 14, 2013, 08:19:33 AM »
Yeah she smelled hot but no leaking antifreeze.
Peace,
johnnywebb
Rio Wil
« Reply #8 on: January 14, 2013, 08:35:11 AM »
I am not so sure your alternator didn't die while on the way to work. By the time you got there, the battery would be very low causing the engine to die and the temp light to blink.  You said it wouldn't start, does the engine crank over strongly and/or have you measured battery/alternator voltage?
Valker
Wahoo!!!!
Texas Panhandle
« Reply #9 on: January 14, 2013, 08:36:28 AM »
...and if the fan just isn't coming on, the relay is bad or a wire is unplugged.
Jeff K
« Reply #10 on: January 14, 2013, 08:37:05 AM »
I'm betting it is electrical not heat.
Will it start now?
Is the battery dead?
Jeff K
« Reply #11 on: January 14, 2013, 08:44:36 AM »
No relay on the fan, just a temp switch on the radiator
SpidyJ
Murrells Inlet
« Reply #12 on: January 14, 2013, 08:47:26 AM »
Will it start now?
She just started right up.  No hot light.
I'm at work and don;t have my manual. Exactly where is the temp sensor?
Peace,
johnnywebb
« Reply #13 on: January 14, 2013, 08:58:01 AM »
The switch is on the left bottom side of the radiator. Remove the wire, ground it with key switch on and the fan should run. If the fan runs the switch is bad which is probably the problem.
Since the coolant level is where it should be and the air temp is cool, I don't think I'd be afraid to run it as long as you can keep air moving thru the radiator.
Any idea why the engine stalled ? If the coolant wasn't too hot [boiling/gurgling] the engine should stay running unless your IS version has some other failsafe item I'm not aware of.
Jeff K
« Reply #14 on: January 14, 2013, 09:03:39 AM »
The sensor for the light is on the thermostat housing. The switch for the fan is on the radiator, lower left inside corner.
SpidyJ
Murrells Inlet
« Reply #15 on: January 14, 2013, 09:29:59 AM »
OK, this is definitely an electrical problem.
She starts right up.
The hot light blinks on/off with the directionals.
When I rev the engine the odometer and the gas gauge flash full and all 8's.
The fan wasn't running cause I didn;t let it run long enough.
I wonder if it's safe to ride home 12 miles??
She stumbled once or twice while I revved it.
UPDATE # 2: battery dead
« Last Edit: January 14, 2013, 09:33:21 AM by SpidyJ » Logged
Peace,
johnnywebb
eric in md
« Reply #16 on: January 14, 2013, 09:34:49 AM »
alt. or bad battery .. keep us up to date if its not running right its the battery ..
SpidyJ
Murrells Inlet
« Reply #17 on: January 14, 2013, 12:44:12 PM »
So while running, the alt should put out 14-14.5 V ......correct?
If not, it comes out.
Peace,
johnnywebb
Oklahoma_Valk
Central OK
« Reply #18 on: January 14, 2013, 01:05:22 PM »
If you can find someone to jump you, you can probably make it to a local autoparts store or walmart to get a new battery. If you keep your revs up, (1500+)  I think the valk will run on just the alternator.
Let those who ride decide.
SpidyJ
Murrells Inlet
« Reply #19 on: January 14, 2013, 01:10:27 PM »
But if the alternator is bad the battery will run down pretty fast and I'll get stuck right?
Peace,
johnnywebb
Oklahoma_Valk
Central OK
« Reply #20 on: January 14, 2013, 01:18:20 PM »
Yes, that is right. However, I would bet that the battery is what is bad.
If the alternator went bad, it would have quit charging your battery on your ride in. This would have left the battery with "X" amount of juice left to power the plugs, electrical, etc. More than likely, you would have died before reaching your destination.
If the battery went bad, your alternator would allow the motor to still run as long as your RPMs were high enough. Upon arriving at your destination, the bike dies....because your RPMs are at 1000 or less.
Bad battery.
If you cannot find anyone to jump you, or get a ride to the auto parts store, I've heard you can put the valk in second, roll, and pop the clutch, and she will start. I think I'd try to get a ride to the autoparts store first though.
Hope you get it figured out!
-OKie
Jeff K
« Reply #21 on: January 14, 2013, 01:22:33 PM »
Bad battery.
-OKie
If the Alternator is not working, and the battery is dead, you can push it from here to china and it will never start. The EMU needs power.
Mr.BubblesVRCCDS0008
« Reply #22 on: January 14, 2013, 03:47:19 PM »
On my I/S the first thing I lost was the dash display. The bike will still run for a short period of time. I pulled my headlight fuse and made it about thirty miles after the display died.
NJF6Cowboy
« Reply #23 on: January 14, 2013, 04:12:29 PM »
Just for Ha Ha's check your starter relay. Mine 99 Interstate was doing all kinds of weird electrical problems on my return trip from Yellowstone this past summer. Temp light, radio, dash lights, hard to start if warm, seemed to be running hot, till it finally died in Penn. 150 miles from home. Repaced melted fuse  in relay and was able to ride home.
SpidyJ
Murrells Inlet
« Reply #24 on: January 14, 2013, 04:47:52 PM »
And then what?  Was it the battery or the alternator?  This is similar to what mine is doing.
Peace,
johnnywebb
vanagon40
Greenwood, IN
« Reply #25 on: January 14, 2013, 07:17:11 PM »
Alternator or Battery?
Get your bike home.  Try charging the battery with a charger.  If the battery will not take a charge, you have a problem with your battery.
Get the bike started (whether with the battery or a jump start).  If you do not have almost 14 volts or better at the battery with the bike at above idle (maybe 2500 RPMs), you ave an alternator problem.
I suppose it MIGHT be possible that if you have a very defective battery, it could drag down the alternator voltage.  But, if the voltage at the battery with the bike running is around 14v or better, your alternator should be good to go.
« Reply #26 on: January 15, 2013, 07:32:09 PM »
 It was the alt. ended up renting a truck and hauling it home 220 miles from the hill country. I got a goldwing alt from HDL overnighted to the house for about 245 bucks and was running the next day.
SpidyJ
Murrells Inlet
« Reply #27 on: January 16, 2013, 11:02:34 AM »
Thanks, will test tonight.. Got hit with a virus yesterday..........oowie, ugh.
Peace,
johnnywebb
« Reply #28 on: January 16, 2013, 03:01:27 PM »
Virus ? You or the 'puter ? Both are going around.
SpidyJ
Murrells Inlet
« Reply #29 on: January 16, 2013, 03:13:43 PM »
me.......... Sad
Peace,
johnnywebb
SpidyJ
Murrells Inlet
« Reply #30 on: January 17, 2013, 03:57:14 AM »
Put on the Battery Tender for 24 hours:
Battery 12.0 V (Bike not running)
Starts right up.
Battery @ 2500-3000 RPM 11.05V
Will order a new alt. and rebuild the old prolly.
Thanks for all the help dudes!!!!!
Peace,
johnnywebb
« Reply #31 on: January 17, 2013, 07:51:45 AM »
This was interesting.
« Reply #32 on: January 17, 2013, 12:07:25 PM »
SpidyJ I would get that battery tested ( put a load on it) to make sure it's good.
My rides:
« Reply #33 on: January 17, 2013, 12:14:37 PM »
When my alt went out it took the battery with it. In ALL fairness the battery came with the Phatt Ghurl and i have zero idea how old it really was. Right after i bought the lady i took the battery out and COULD NOT find a manufacture or install date. And my first indication of problems was whe the L E D display and the instruments crapped out. If yer tight on bucks go to the M A R S website. He is in Indiana and is a straight up guy to deal with. RIDE SAFE.
SpidyJ
Murrells Inlet
« Reply #34 on: January 17, 2013, 12:27:18 PM »
I've only owned her a little over a year and the battery was brand new then.  I will for sure have her tested cause it's free..........and if it's free, it's for me!!! crazy2 Grin
Peace,
johnnywebb
« Reply #35 on: January 17, 2013, 08:14:13 PM »
'97 Goldwing Aspencade
Part # is 31100-MT2-015
"The terminal & plastic insulator are different where you connect the alternator battery wire. You have to take off the capacitor that is mounted on the Gold Wing alternator and rotate the front housing to match the holes from the Valkyrie model so that it will fit."
As per Ron Ayers Parts Fiche, alternator 31100-MT2-015 fits on the 30 following GL1500 Goldwing models :
Honda GOLD WING GL1500 (1988 to 1990)
Honda GOLD WING ASPENCADE GL1500A (1991 to 2000)
Honda GOLD WING INTERSTATE GL1500I (1991 to 1996)
Honda GOLD WING SE GL1500SE (1990 to 2000)
 A lot cheaper that a valk alt and works like a charm.  Mine has been on for over 60'000 miles. You just have to clock it.
SpidyJ
Murrells Inlet
« Reply #36 on: January 20, 2013, 10:29:12 AM »
Just had the battery checked and it is fine.
Alternator is out.
Waiting for the new one to come tomorrow.
Peace,
johnnywebb
« Reply #37 on: January 20, 2013, 10:44:17 AM »
I hope that fixes it. If you're keeping the old alternator, you could take it apart and give it a look. These have a tendency to pull apart/open a rotor wire. If thats the case it might be able to fix somewhat easily.
Challenger
« Reply #38 on: January 20, 2013, 04:35:21 PM »
Glad you figured it out. A buddy's Goldwing quit charging last fall. We pulled it apart and found one brush stuck in the holder. I soldered in a new set I keep around for the Valk and all is well. Cheap fix.
SpidyJ
Murrells Inlet
« Reply #39 on: January 21, 2013, 10:12:49 AM »
Ya know, I must say......I have literally pulled hundreds of alternators in my day as a part time mechanic.
I have never seen such a dirty piece. Such dust, grime and dust bunnies clogging the vent holes.
Peace,
johnnywebb
