February 10, 2026, 04:47:28 PM *
Author Topic: Wiring for "Dummies", part one  (Read 1426 times)
JimmyG
« on: June 22, 2015, 10:39:08 AM »
JimmyG
« Reply #1 on: June 22, 2015, 10:53:03 AM »
OK, OK, I'l go for pictures for Dummies first :2funny
Wiring gurus, are these two wires in front of the red plug, the accessory wires for wiring up a relay?
My bike is a 1999 I/S   I want to add a gps unit.
« Last Edit: June 22, 2015, 10:54:59 AM by JimmyG » Logged
rhinor61
Northern California
« Reply #2 on: June 22, 2015, 11:00:43 AM »
Jimmy that would be them.
a 12vdc test light is the best way to verify of course.
- Ground is the male (bare) bullet connector
+ positive is the female insulated bullet connector.
the 12vdc will power on when the key is ON.
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
knockdolian
« Reply #3 on: June 22, 2015, 12:29:49 PM »
No, I was asking about Acc sockets before. Those I believe are to do with the CB along with the white one.
http://www.valkyrieforum.com/bbs/index.php/topic,78002.0.html
« Last Edit: June 22, 2015, 12:33:14 PM by knockdolian » Logged
JimmyG
« Reply #4 on: June 22, 2015, 12:45:26 PM »
Well, ok, 50/50. One yes, one no, that clears things up by golly Grin
knockdolian
« Reply #5 on: June 22, 2015, 12:59:38 PM »
Fair point. Mine is IS. If you read the post on the link you will see IM RIGHT  cooldude
JimmyG
« Reply #6 on: June 22, 2015, 01:24:52 PM »
knockdolian, I just read the link(overlooked before), and by golly, now I am going hunting for those wires.  Thank you sir Wink
JimmyG
« Reply #7 on: June 22, 2015, 01:45:38 PM »
I found them, tucked away , so short that it's not funny!  Thanks for the link and photos, otherwise, I may have never found them. cooldude  Are those 4mm females for bullets connectors or 3.5mm?
« Last Edit: June 22, 2015, 01:54:27 PM by JimmyG » Logged
« Reply #8 on: June 22, 2015, 03:02:21 PM »
I believe all the Hondas are 3.5mm. You need to get them somewhere else than a regular place.
vintageconnections.com is one of those online places. They have all those special connectors for all you plugs on the bikes.
ptgb
Youngstown, OH
« Reply #9 on: June 22, 2015, 03:38:49 PM »
Those are NOT the ACC hookups.
Those are the plugs for rear passenger PTT CB button
Bought and hooked one up years ago.
JimmyG
« Reply #10 on: June 22, 2015, 07:31:09 PM »
Uhhh, little late on the draw there ptgb, but appreciate the answer anyhow. Yeah, I checked the link in knockodolians post and he led me to them little suckers hiding way back in there mongst the rest of the dirt and dust.  Wink
knockdolian
« Reply #11 on: June 23, 2015, 01:45:11 AM »
I cut the wire at the fuse box and extended it to power an MP3. You can get a neg from anywhere
Paladin528
« Reply #12 on: June 23, 2015, 08:04:10 AM »
I just used those exact 2 wires on my 99 I/S to power a relay for some lights.  The power is off unless the ignition switch is set to ON.  Worked perfect.  wired it with some bullet connectors so no cutting required.
Paladin528
« Reply #13 on: June 23, 2015, 08:06:15 AM »
According to the owners manual they ARE the accessory connectors
JimmyG
« Reply #14 on: June 23, 2015, 11:28:44 AM »
Well, I got my phat girl wired up with a relay to run the gps port. thanks for the help gents, great site to learn and even us electrical"Dummies", can wire things up and make them work. Smiley Thanks again  cooldude
Bagger John - #3785
« Reply #15 on: June 23, 2015, 12:57:06 PM »
No.
The Std/Tourer CB's rear PTT connectors are the bullet type but originate from the radio itself. The I/S' counterpart (at least, on the two I've owned) is built into the harness and uses a Hitachi keyed connector like other wiring subassemblies on the bike. The connector in question can be found in the clear plastic hood which also contains the connectors for the bike's rear lighting.
Those wires are treated as "ACC" (5A max) on the I/S and as "CB Power" on the other two. Best approach to interfacing with that circuit is to use it to activate a relay which supplies power to a Power Plate, Fuze Block or similar distribution bus.
« Last Edit: June 23, 2015, 01:00:51 PM by Bagger John - #3785 » Logged
