February 11, 2026, 02:01:21 AM *
Author Topic: Nightmare, Part II  (Read 1439 times)
Stryk
Panama City, Fl
« on: July 31, 2015, 01:40:19 PM »
I need some input about where to go from here.  My 2003 carbs started leaking, then I assumed hydrolocked.  Just went to start it and it acted like a low battery, turned over a couple times, stopped and the starter just started spinning.  My nephew said he had a friend that could fix it.  The guy came over and took the tank and carbs home to clean them - that was about a year ago. ( A lot happened in this time to get me off track.  My illness and the death of a close family member)   He wouldn't answer calls or voicemail and finally had to threaten law enforcement.  It worked.  A couple days ago he dropped off the tank and 3 partial carbs at a family member's house and left. He will not respond to questions of where the heck are the rest of them.  I have recently bought another set of carbs from a running bike that was being scrapped, so I now have everything I need to start repairs. So, where do I start?? Who can walk me through the repairs.  I can do most anything mechanically, but need guidance with starter gears, vacuum lines, and syncing the carbs.
Retired and loving it
« Reply #1 on: July 31, 2015, 06:56:25 PM »
To keep things short and sweet, I would remove the starter, and look inside for broken gears.
I don't know if you did have a hydro lock or even damage to your bike. I feel most troubles can be fixed with a liquid carb cleaner, and the PROPER method of using it, will get most bikes moving again.
You are looking for something like this.
http://www.valkyrieforum.com/bbs/index.php/topic,70306.0.html
« Last Edit: August 01, 2015, 11:10:03 AM by gordonv » Logged
Stryk
Panama City, Fl
« Reply #2 on: August 01, 2015, 06:45:53 AM »
That is EXACTLY what I was looking for - THANKS.
Momz
ABATE, AMA, & MRF rep.
« Reply #3 on: August 03, 2015, 07:48:44 PM »
Dude,....your motor got hydrolocked. Putting additives in your fuel now will not fix the problem.
Get a workshop manual (online from Dags valkyrienorway site) and do a search (on this site), roll up your sleeves and prepare to tear down and inspect.
Good luck
ALWAYS QUESTION AUTHORITY!
« Reply #4 on: August 04, 2015, 05:56:53 AM »
Well, with the starter motor spinning, I'd certainly suspect a hydrolock event, and
an inspection is certainly indicated to determine if any internal parts are broken.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: August 04, 2015, 05:59:36 AM »
You can download the Service Manual here:
http://valkyrienorway.com/download.html
So many roads, so little time
VRCC # 5258
sudsman
« Reply #6 on: September 29, 2015, 05:01:58 PM »
More than !ikley engine removal and partial tear down for starter issue pull plugs and see if starter will spin engine over tape up any wires before powering up.
