February 11, 2026, 07:00:30 PM *
Author Topic: Speedo cable at speedo clicking after front wheel install  (Read 1046 times)
« on: April 18, 2016, 11:59:44 AM »
Fitted new front tire, brake pads.
Put everything back together. Rode bike down my short driveway click click click .
Back into garage and on to lift. Removed speedo at wheel and reassembled. Still click click click.
Back into garage and on to lift for the second time. Removed speedo at wheel and reassembled. Still click click click.
What do I need to do to stop it clicking???  Sad
EDIT
Forgot to mention that the inner cable is easily shaken to reveal the slot at the lower end as the cable slides out of the outer casing.
« Last Edit: April 18, 2016, 01:41:47 PM by Britman » Logged
« Reply #1 on: April 18, 2016, 03:09:35 PM »
Your left fork is too far to the the right.  By either tapping the axle in more, or repositioning the fork tube so its flush with the head of the axle, then, with the left side pinch bolts retightened, do the rest over and that should fix it
« Last Edit: April 18, 2016, 03:15:22 PM by Chrisj CMA » Logged
« Reply #2 on: April 18, 2016, 06:01:32 PM »
+1 on the axle.
http://www.valkyrieforum.com/bbs/index.php/topic,58071.0.html
Speedo gear on the wrong side of the stop notch?
« Reply #3 on: April 18, 2016, 08:30:59 PM »
#1 had this happen to me one time .
« Reply #4 on: April 19, 2016, 08:30:02 AM »
Thanks. All is happy in speedo land  Cheesy
No, not the nut hugging swimwear favored by overly large Mediterranean males.
« Reply #5 on: April 19, 2016, 06:22:50 PM »
2funny 2funny
« Reply #6 on: April 19, 2016, 08:20:01 PM »
And the answer to the question was? Enquiring minds would like to know. Also anyone doing a search in the future.
Thank you
N8171S
Marlboro, Mass
« Reply #7 on: April 20, 2016, 03:21:26 AM »
It is probably the rivits on yoour brake disk hitting the caliperr not the speedo cable.  The axle needs to be adjusted.
« Reply #8 on: April 20, 2016, 05:35:09 AM »
Nope. Sound was from speedo.
Chris's answer was the correct one for my situation.
« Reply #9 on: April 20, 2016, 02:59:20 PM »
Was my speedo cable also.
