February 12, 2026, 09:46:38 AM *
Author Topic: Swapping heads vs cams  (Read 1778 times)
Corndog
Victoria, BC
« on: August 11, 2016, 05:32:13 PM »
Looking for another opinion on a cam swap. I have a set of cams from a 97 49 state bike that I'd like to put on to replace my cali's. The heads are complete, but not as nice of shape as the ones on my bike now (some corrosion, and it looks like there may have been a repaired exhaust stud). Not a deal breaker, but what is the consensus about just swapping the cams? My only real concern is a mismatch in the journal wear of an higher mileage cam (50k mi vs 20k mi on the heads). Also, I forgot to order new exhaust gaskets  tickedoff
« Reply #1 on: August 11, 2016, 06:58:39 PM »
I believe there have been others that changed out just the cams.
« Reply #2 on: August 11, 2016, 07:24:21 PM »
I would just like to know if anything is wrong with the bike as is?
Tfrank59
'98 Tourer
Western Washington
« Reply #3 on: August 11, 2016, 07:27:50 PM »
I thought 97 cams were different then subsequent years, are they interchangeable?
-Tom
Corndog
Victoria, BC
« Reply #4 on: August 11, 2016, 07:44:50 PM »
Well I dug into it. These 97 49 state cams have R2 cams :\
Should have checked before I got this far down the rabbit hole.
« Reply #5 on: August 12, 2016, 02:49:18 AM »
I also was contacting some ebay seller's, found one 49 state '97 that had R2 cams, some '99 and '00 had R2 and were not ca bikes.
One bike had R1 one side and R2 the other side, it was a '99.
Why I suggest everyone to check. R1 will pick up about 10/10 and 3-4 MPG, from all the research I have done. The R2 causes Internal EGR to happen, doesn't work right if it isn't variable cam timing and ignition being monitored by a computer. When the external EGRs went away in vehicles they all use Internal EGR.
http://www.valkyrieforum.com/bbs/index.php/topic,80073.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,88071.0.html
Blackduck
West Australia
« Reply #6 on: August 12, 2016, 04:14:47 AM »
Looks like there are at least 3 grinds for the Valk cams
Next time I have the covers of my Aussie unit I will check the ID on the cams
Cheers Steve
« Reply #7 on: August 12, 2016, 04:20:20 AM »
That's interesting Steve, never saw that before. Wonder if a different "R" number.
« Reply #8 on: August 12, 2016, 06:49:25 AM »
Cheers Steve
Hmmm, that is interesting.
« Reply #9 on: August 12, 2016, 06:55:51 AM »
This engine puts a lot of oil up into the cam/rocker area, u should be good to go. just use assembly lube mix recommended in the tech manual.
« Reply #10 on: August 12, 2016, 04:23:45 PM »
If you look in archives I think this has already been done with limited success and with dyno results. The cams really dont provide any real gains. I would also check journal specs as long as they are the same and as long as when you tighten them up they turn freely I dont think you would have a problem.
« Last Edit: August 12, 2016, 04:25:58 PM by Robert » Logged
Itinifni
Boston
« Reply #11 on: August 12, 2016, 05:24:27 PM »
Howdy all, I've been reading this forum since I picked up my 97 Standard a few months ago, figure it's as good a time as any to open my mouth (figuratively speaking). Aside from being a long time Honda rider (started with a CT 70 in the mid-70s) I've spent 35 years on the technical side of the automotive industry so here's my $0.02.
As Robert suggested first thing to do is confirm the journal specs are the same. Assuming they are I'd inspect journals on both the original and replacement cams for any irregular wear. Also inspect the cam saddles and caps, again for any unusual wear. Chances are any problems will show up in the aluminum of the saddles/caps before on the cam journals.
If all that looks ok you're good to move on to the next step and I believe this is important.
I would not even consider using rocker arms that have worn in on one cam on another cam. There's a reason that you should always use new rockers (or lifters if that's the case) when installing a new cam, these are wear items that mate together during break-in.
What I would do assuming all parts are in serviceable condition:
Swap cams
Swap rocker arms and rocker shafts (the arms are also mated to their respective shafts) ***be sure to keep the individual arms on their original cam lobes***
I would also go so far as swapping the tappet adjusting screws from the original rockers into the replacement rockers keeping them with their respective valves (after all they too are mated together).
I'll admit, swapping the rocker shafts and adjusting screws may seem a little over the top but like I said, I would not consider using old cams from one engine with old rockers from another.
Good luck with the swap if you decide to do it.
BTW Great forum
Matt
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
97 Valkyrie Std. (May surpass the GL1100 as the best bike I've ever owned, I'll update in 50k miles)
Corndog
Victoria, BC
« Reply #12 on: August 13, 2016, 10:12:02 AM »
So the saga continues...
After discovering that the heads from the '97 49 bike had two R2 cams in it, it didn't make alot of sense to swap the heads (or cams) into a bike with the California heads/cams currently on my bike.
Instead, I pulled the valve covers off to check valve clearances. Most were good, a couple tight ones. However, I looked at the cams and low and behold:
Left Side
http://i.imgur.com/T8dd8k1.jpg
Right Side:
http://i.imgur.com/cYARswD.jpg
I've heard about this before, but I have no idea what the implications are.
Conveniently, ebay has a used Left R1 cam... but I need to check its journals vs spec.
« Last Edit: August 13, 2016, 10:15:00 AM by Corndog » Logged
« Reply #13 on: August 13, 2016, 10:29:49 AM »
Left Side
Right Side:
the one on ebay is the bike I had mentioned, one R1 and one R2.
so your's is bike No. 2 that is known for this. Pretty bad quality control by Honda.
will run much better with the same cams.
Corndog
Victoria, BC
« Reply #14 on: August 13, 2016, 10:40:50 AM »
Thanks. I love being different  Roll Eyes
I am a bit concerned with the ebay cams installed with my current lifters. Both have been worn separately.
« Reply #15 on: August 13, 2016, 10:47:26 AM »
there are no lifters, just rocker arms. many feel its not an issue.
Corndog
Victoria, BC
« Reply #16 on: August 13, 2016, 10:53:35 AM »
Misspoke, but you got my drift. Thanks for the input! I really wish Honda would have their crap together when they built these 2 bikes... Maybe mine and the ebay bike were side by side on the assembly line  Wink
Corndog
Victoria, BC
« Reply #17 on: August 13, 2016, 12:54:15 PM »
Well I'm a bit unsure about that cam now. The manual lists the service limit of the Journal OD's at 1.059". The ebay cam is right at the SL (1.0610, 1.0605, 1.0585, 1.0590). I'm going to have to sit with this.
pancho
Bonanza Arkansas
« Reply #18 on: August 15, 2016, 07:58:06 AM »
I can't stand it any more,, my 49 state 97 has never gotten better than 32 MPG with several states of carb tuning and Cobra pipes,, stock size jets at present,, I've often wondered why. I am going to pull the covers and take a look at the cams,, plus it's a good time to check the lash adjustment.
« Reply #19 on: August 15, 2016, 10:18:58 AM »
Swap cams
BTW Great forum
Matt
Great post Matt,
don't be shy, keep posting.
And welcome to the forum and the Wonderful World of Valkyries.
« Reply #20 on: August 17, 2016, 05:44:17 AM »
I looked at the manual last night, it also states to check the head journals and then subtract to the two #s to get an oil clearance #. The oil clearance is the past/fail measurement if I read it right. it was late when I read it.  Undecided
