February 12, 2026, 02:40:51 PM *
Author Topic: Gas mileage down, smell raw gas.  (Read 1120 times)
Valker
Wahoo!!!!
Texas Panhandle
« on: October 16, 2016, 06:48:16 AM »
I know this has been addressed before, but my search ability must suck. I had BigBF replace all my vacuum lines awhile back, but since then, my mileage has dropped about 5-7 mpg and I smell raw gas. I cannot find liquid gas anywhere, and it runs fantastic. Can anyone point me to a starting place?
Pete
« Reply #1 on: October 16, 2016, 07:10:52 AM »
Start with checking the gas cap seal and the keyhole.
Then the air vent hose.
And the weep hole on the fuel petcock.
Overflow hoses on the carbs.
All vacuum line connections and plugs.
Intake o rings.
Fuel hose and carb connectors.
signart
Crossville, Tennessee
« Reply #2 on: October 16, 2016, 07:49:28 AM »
Make sure your enricher linkage is working properly. If you're "enriching" it will run like a scalded dog, but guzzle the fuel.
« Reply #3 on: October 16, 2016, 01:37:27 PM »
Stock petcock?? Hole in the diaphragm. Go on ahead and ask me HOW I Know!! RIDE SAFE.
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: October 16, 2016, 02:00:11 PM »
Sorry, I forgot to say it's a manual Pingel with Interstate tank. I have 148,000 on it.
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: October 16, 2016, 05:36:15 PM »
You could have a hole in the vent tube inside the tank. It would drain thru the vent as your riding and flow out and under. Or the sending unit could have a bad gasket too. My bike had a leaky gas cap seal.
« Last Edit: October 16, 2016, 05:38:26 PM by Steel cowboy » Logged
2001 black interstate
2003 Jupiter Orange wing
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: October 16, 2016, 05:51:05 PM »
Thanks. I will start looking where y'all stated.
Grandpot
Fort Mill, South Carolina
« Reply #7 on: October 17, 2016, 05:34:23 AM »
If you find that your ga cap is leaking, here is a quick and inexpensive fix.  I have used this for the past few years, it works.  http://www.valkyrieforum.com/bbs/index.php/topic,57951.0.html
