February 12, 2026, 08:59:31 PM *
Author Topic: How do I know when I need a clutch replacement?  (Read 3463 times)
wellandfit
Fredericksburg TX
« on: February 01, 2017, 02:29:05 PM »
The clutch lever on my 99 (86k miles) has little distance to the handle.  When I put it in gear it wants to serge forward even with the level fully engaged.  My mechanic bled the clutch, but little difference.  Is it time for a clutch replacement?
« Reply #1 on: February 01, 2017, 02:58:30 PM »
If you're confident your mechanic bleed the system properly and enough, then the next think I would check would be the slave cylinder.
You can take it out and inspect it relatively easily, I would suggest getting a service manual if you don't have one.
Making sure the system is clean and the master and slave are working properly is the first step and should be done even if you need to open her up to inspect the clutch.
Firefighter
Harlingen, Texas
« Reply #2 on: February 01, 2017, 05:39:55 PM »
Do you mean it pulls constant while in gear with the clutch pulled (engaged)?? Mine will sometimes bump forward when I go from neutral to first gear.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Pete
« Reply #3 on: February 01, 2017, 06:13:29 PM »
On the surface based on your complaint, it sounds like a master or slave cylinder issue.
Not enough pressure and travel to disengage the clutch.
Rebuild kits are available for both and are inexpensive.
Any fluid leaks on either? If so rebuild that one first.
« Reply #4 on: February 01, 2017, 07:09:19 PM »
Check your lever handle pivot bolt first.
http://www.valkyrieforum.com/bbs/index.php/topic,83167.0.html
« Last Edit: February 01, 2017, 07:14:13 PM by gordonv » Logged
« Reply #5 on: February 01, 2017, 07:21:51 PM »
+1, mine was so deformed and wore recently I'm surprised it worked at all.
wellandfit
Fredericksburg TX
« Reply #6 on: February 02, 2017, 06:40:29 AM »
Hey, thanks Guys!  I am no mechanic.  Installing a re-build kit sounds scary.  How would I know if the problem is with the pivot bolt?  What would I look for to verify the pivot bolt is the problem?
Yes, it wants to keep moving forward.  Also, it's become impossible to get in neutral when stopped.  I have to cut it off to get in neutral.
That service manual is a good idea.  Where can I get one?
I live some 60 miles from the nearest Honda dealership.  I'm afraid I'll have to get them to come pick up the bike, fix it and deliver it.  Ouch!!  My local mechanic won't touch the clutch issue on the Valk.
I sure do appreciate you guys!
Bone
« Reply #7 on: February 02, 2017, 07:05:04 AM »
Where are you located I'm in southern Michigan 35 miles NW of Toledo , Ohio.
« Reply #8 on: February 02, 2017, 08:05:10 AM »
http://www.ebay.com/itm/NEW-Honda-GL1500-C-CT-CF-Valkyrie-GL-1500-1984-1987-Clymer-M462-2-Repair-Manual-/182390590027?hash=item2a77538a4b:g:ecwAAOSw44BYU55r&vxp=mtr
http://www.ebay.com/itm/New-Service-Manual-97-03-GL1500C-Valkyrie-GL1500-OEM-Honda-Shop-Repair-Book-P21-/272240536979?hash=item3f62cced93:g:SRMAAOxyYSdTBpMU&vxp=mtr
I don't have the Clymer Manual, but I hear it's competent.  I like the Honda OEM.
They come up from time to time on Ebay and here in the classified section.
Mtn Valk
North Ga.
« Reply #9 on: February 02, 2017, 08:16:42 AM »
+1 on the clutch lever handle pivot bolt. May even just need cleaned out and lubricated, but due to the miles, replacement is best. You wouldn't think it would be such an easy fix. Hopefully it will be just that.
J3
KG
Munford Tennessee
« Reply #10 on: February 02, 2017, 09:01:49 AM »
download the manual
http://www.valkyrienorway.com/download.html
What we do all have is a limited number of days to devote to whatever we love in this life.  Not all the same number of days but all have limited days....Willow
« Reply #11 on: February 02, 2017, 09:05:44 AM »
Here you may download a free bootleg copy of the manual.  (from Norway)
I like having a real one, which can be ordered online; $60 last I checked.
Occasionally there has been a copy for sale on our classifieds.
EDIT: KG beat me;  is there an echo in here ?   Grin
« Reply #12 on: February 02, 2017, 05:30:38 PM »
How would you check the pivot bolt? It's kind of hard to explain, I think it's something you sortof know or not.
Inspection. Maybe remove the bolt and then look it over. We are looking for something out of round or bolt/shaft/bushing with signs of being worn.
While off the bike, inspect the pivot point while pushing the lever towards the grip.
« Reply #13 on: February 02, 2017, 07:06:32 PM »
It's brass and on inspection the wear is obvious. Look there first. Replaced mine on Deerslayer thousands of miles ago.
wellandfit
Fredericksburg TX
« Reply #14 on: February 03, 2017, 07:58:29 AM »
Thanks again for all the considerate replies!  I live in Fredericksburg TX.  I contacted the Honda dealer in San Antonio and the said they do not work on bikes older than 10 years.  The service mgr. was very helpful and referred me to a certified independent mech.  about 60 miles away from me.  I called and he seems like a stand-up guy.  Said he would pick up the bike, repair it and bring it back.  I asked what the worse-case scenario money wise would be.  He said if a new kit is required the total cost would be around $350.  I though, not bad, so he's coming next week.
« Reply #15 on: February 03, 2017, 12:15:15 PM »
Wow.  That brass part is a few bucks and is available from partzilla for one, and will take you maybe 5 minutes to change.  Got any other work you'd like to farm out, I'd like to score $350 for such little work...  Here's the part: http://www.partzilla.com/parts/detail/honda/HP-22885-MB0-006.html
#2 in the diagram:
« Last Edit: February 03, 2017, 12:18:37 PM by MarkT » Logged
« Reply #16 on: February 03, 2017, 04:07:05 PM »
I think what MarkT is getting at, is with very little skill, help from the Forum, and the Service Manual helps too, you should be able to do almost anything yourself.
So far, we are suggesting inspecting the parts, the most common wear part is the handle itself. Suggested post where you are, so someone close by might chime in and volunteer to help/look it over also.
wellandfit
Fredericksburg TX
« Reply #17 on: February 05, 2017, 01:57:43 PM »
Thks Gordon!  Perhaps mark didn't read the worst-case scenario.  That would be pick up my bike from 60 miles away, install a new kit, and deliver back.  It may indeed be as simple as Mark suggests and I sure do appreciate the diagram.  I am the least of the worst when it comes to mechanics so it seems my best option to go with the fellow I found.
« Reply #18 on: February 05, 2017, 05:28:48 PM »
I wonder how far away Big BF is from you? AZ I believe, Phoenix maybe?
Also Attic Rat, same thing, I don't know where he is.
You can look them both up. BF travels every year, months on the road meeting up with Valks and fixing them.
wellandfit
Fredericksburg TX
« Reply #19 on: February 06, 2017, 12:34:37 PM »
Mark wrote:  "It's brass and on inspection the wear is obvious. Look there first. Replaced mine on Deerslayer thousands of miles ago."  Please elaborate, Mark.  Are you referring to the bushing at the lever?
Also,  I'm no mechanic, but am I wrong in suspecting that since there is so much "play" in the clutch lever that the problem is there.  I'm thinking this wondering, if the problem was within the internal workings of the clutch, why would that make the clutch lever so loose.  I'm considering taking the lever bolt out and examining it.  What would I look for that would prove it was the problem?  Would it help to take photos and submit them here for you experts to look at?
Pete
« Reply #20 on: February 06, 2017, 03:18:54 PM »
Perhaps but not necessarily. Could be the clutch does not complete release so the slave cylinder does not force the fluid into the master cylinder. Also could be the master cylinder hangs in the bore and does not return all the way.
Could also be the brass bushing is missing causing the play.
Take the lever apart and see what you find.
wellandfit
Fredericksburg TX
« Reply #21 on: February 07, 2017, 08:34:42 AM »
Ok guys, I took the lever off and the bushing is pretty worn and not round as it should be.  Ordered a new one today.  I can see where this might help with the loose lever, but how about the distance between to the handle?  The lever is way too close.
« Reply #22 on: February 07, 2017, 08:43:23 AM »
Your new bushing might help with that.
falconbrother
« Reply #23 on: February 07, 2017, 10:19:40 AM »
I think that I would be real suspicious of that master or slave cylinder based on the symptoms you describe.  I would try a reverse bleed and see if that had any effect.
« Reply #24 on: February 07, 2017, 08:49:31 PM »
One thing at a time.
You've inspected and discovered a problem. You're doing the right thing, fix it.
After it's fixed, see if the problem is still there. Same, less, more or gone. From there, you can post again with the results, and see what to do next.
Yes, I would also agree with cleaning the fluid, but I would do them all at the same time. If you don't know who, or haven't done it yet yourself, seek help. I bought a vacuum bleeder, when I parted out my bike. A Mitty Vac, but HF has a clone for about half the $. Should also be able to pick it up on one of their many sales.
But I still like doing one things at a time, so after it's fixed, you know what the problem was, rather than it could have been any one of a number of things you fixed.
wellandfit
Fredericksburg TX
« Reply #25 on: February 08, 2017, 10:36:27 AM »
OK Valk pals, thanks to ya'll I'm making progress.  Found this guy through YouTube.  Incredible!
http://motorcyclemd.com/motorcycle-clutch-slave-cylinder-rebuild/
Thanks so much to you all!
Bill Mc
Pete
« Reply #26 on: February 08, 2017, 01:55:03 PM »
Rebuilding a master cylinder on a bike is usually quite easy.
Mostly 2 things disassembly/reassembly with new parts and thorough cleaning of everything before reassembly. About 99 time out of 100 that fixes the issue.
Perhaps you could say 3 if you include bleeding the system.
On disassembly lay everything out in order as it comes apart.
Then clean everything and then substitute new parts.
Reassemble in reverse order.
Lightly lube rubber parts with clean brake fluid for an easier assembly.
Good luck.
« Reply #27 on: February 08, 2017, 02:52:47 PM »
At 86k I doubt you would need a clutch. Mine is well past 100k and no issues. Do as these guys suggest and take it one step at a time. Mechanical or not you can fix/ repair most anything on this bike.
Keep us updated :cooldude:and your chin up our girls are getting long in the tooth so to speak. And that dealer that said no work on 10+ yr old bikes is because all of their mechanics were still pooping their pants ten yrs ago 2funny
six2go #152
Ft. Wayne, IN
« Reply #28 on: February 08, 2017, 03:50:26 PM »
A problem that no one else seems to want to mention is maybe your clutch rivets are sheared. Mine happened right at the mileage that you have. The symptoms I experienced were;
1) Clutch lever would hit a solid stop before it got to the grip leaving a gap between the lever and grip.
2) The Valk would want to creep forward while stopped and in gear and the clutch pulled in as far as I could(That solid stop thing again).
3) Almost impossible to get into neutral when stopped, and not much easier when rolling.
4) Shifting while riding wasn't smooth as normal.
Several of the guys here have fixed this themselves but I don't get down on the garage floor like I used to, so I took it to my trusted dealer and told them to replace everything that was affiliated with the operation of the clutch. Yes, it cost me some $$, but that was the first and only problem I had in 17 yrs. of ownership so I didn't scrimp, I just wanted it good to go for another decade or so.(Then I traded for an F6B  Smiley )
BradValk48237
Oak Park, MI
« Reply #29 on: February 10, 2017, 12:56:39 PM »
Ill bet once he replaces the bushing his problem will go away.....
B
wellandfit
Fredericksburg TX
« Reply #30 on: February 10, 2017, 03:56:55 PM »
Well Brad and others may be on to something.  I replaced the bushing and the lever is all the way out.  But, it only comes half way the handle now.  Started the bike, but it shut off when putting it in 1st gear after a brief pause.  Some progress but still questions.
« Reply #31 on: February 10, 2017, 04:08:55 PM »
That doesn't sound like good news.
You're saying after a new bushing, there's little or no play in the lever and it will only go halfway to the grip?
You're sure you got the end of the rod into the hole of the bushing?
« Reply #32 on: February 11, 2017, 05:07:53 AM »
That sounds dirty  Grin
Bone
« Reply #33 on: February 11, 2017, 08:14:42 AM »
six2go may have it with rivets.
« Reply #34 on: February 11, 2017, 10:46:02 AM »
Most times when there is talk of the rivets, this is an intermittent problem, comes and goes, even a little bit, the lever action not always the same.
Nothing wrong with doing the easier and simpler things first. Lever, pivot and plunger. Slave. Bleeding.
I would do all these things, and more, before concluding the clutch plates. It can be a fairly easy job, but takes planning. Remove motor or not. Proper sockets. Parts. And Time.
« Reply #35 on: February 11, 2017, 11:33:33 AM »
If the lever only comes in half way I am gonna bet you need clutch plates,sounds as if the rivets are sheared.
« Reply #36 on: February 11, 2017, 04:39:17 PM »
Umm, only to a pervert   Roll Eyes Smiley
Wait, I resemble that remark  Shocked
