Im on the road need help
Started by Slick, Fri 07, Sep 2012, 10:39:14
Previous topic - Next topic
Slick
Headin to Savannah for a vacation
And we are in Mims Florida and the bike started makin a clicking noise when leaning left. Can I keep riding or anyone nearby that can guide us-HELP
1999 Valkyrie Interstate,
2003 1800 VTX
Dogg
Is it coming from the front wheel or rear wheel? Ifits front, its the caliper because of the bearing, probably. If its the rea, its the splines because of the bearing, possibly. Safe or not is your call. But id try to find bearings for it....
Slick
Sorry coming from the rear I can be reached at 561 358 9489
2003 1800 VTX
I'm with Dogg...  sounds like bearings either front or rear.
From Jeff K's generic parts page.... Since I don't know what year of your bike (1997's are different), here's the whole list.
xxxxxxxxxxxxxxxxxxxxx
Wheel Bearings
1997 Front 6004-2RS
1998-2000
Front, 6204-2RS or  6204LL
And all models left rear 6204-2RS or  6204LL
(same bearing different mfg.) 6204 is size, letters indicate sealed both sides. See below about seal designation
1997-2000 All right rear  5204?? Double Row Angular Contact Bearing
They need to be sealed both sides.
MRC #5204ZZ
RSR #5204EE
IKS #52042RS
xxxxxxxxxxxxxxxxxxx
Hay  8)
Slick
Can I limp the 130 miles home or...........
2003 1800 VTX
Slick
More info- had new pads installed Wed. And when I ride in a left circle and apply the rear brake the noise goes away . I also had a bit of a short semi panic stop and it was after that the sound started
2003 1800 VTX
billyboy
Slick; Just posted on the Fl. board. I'm on the west coast so I woudn't be much help. I did post your #. Good luck. Bill
Ok, with this new info, it sounds like your rear brake caliper is not "floating" on the pin like it should.  If you feel no vibration at 30-40 mph in a left curve AND the clicking stops when applying the rear brake, I think you are good to get home.
I have had this same noise that sounded like the rear brake wasn't releasing all the way and dragging on the rotor.  Pressing lightly on the rear brake stopped the noise.  After a few miles (about 100 or so) the noise quit.
Your mileage may vary.
Hay  8)
Thunderbolt
Left him a message about a couple of Honda dealers in Daytona.  He must be riding back home.
Slick
Well for better or worse we trudged on. Right now sitting in a Waffle House in Brunswick, Ga having a delightful iced tea. The noise seems to be dimenishing so I'm hopefull that it's the brakes. Bike is running and stopping fine- Terry I got your message and I thank you-
2003 1800 VTX
billyboy
Glad to hear it. Have a safe trip and enjoy the wind. Bill
Dogg
Jimmy was right on the money, rear caliper is not sliding right. Itll go away after a while but reccomend pulling caliper and re lubing slide.
Slick
Good Mornin all-
Stayd in Brunswick last night, and heade into Savannah in a bit- I want o thank you all or the advise and concern. My wie was blown away bthe people that called to offer help. I told her thats what family does, so thank you again VRCC family--
Slick-
PS- I'll check in again later from Savannah-
2003 1800 VTX
Anytime Slick.  We can easily put ourselves in your position.
This big ole dysfunctional family we belong to.....  :)
Hay 8)
