News:
Main Menu
Speedometer
Started by robin, Fri 02, Aug 2013, 18:58:07
Previous topic - Next topic
robin
Is there anyway to tell if it has in fact rolled over?
Daniel Meyer
Quote from: robin on Fri 02, Aug 2013, 18:58:07
No. But, you can get a carfax on it, some states report the mileage on inspection and that will show up on the report. Also, mileage is generally recorded on title transfer.
CUAgain,
Daniel Meyer
Moonshot_1
Just the simple fact that one has to ask such a question is a testament to the quality of these machines. :cooldude:
Mike Luken
Cherokee, Ia.
G-Man
Quote from: Moonshot_1 on Fri 02, Aug 2013, 20:02:38
:cooldude:   :cooldude:   :cooldude:
3W-lonerider
if the state where the bike is registered has an annual inspection. ask the owner where he takes the bike. you can go there they should have a record dating back several years.
the mileage will be written in the inspection book.
T-Bird
I haven't checked in a few years....but carfax doesn't do motorcycles.
They may have started now
Fritz The Cat
Mine's a Canadian version that recently turned over. Strange watching the speedo show all zeros again. I wonder how many more times it will turn over.
Rio Wil
The interstate has a hundred thousand digit (six 9's) the others go to five  9's........if the indicated mileage is between say 00000 and 12000, take a look at the date code on the tires.  Date code of 0205 could suggest year 2002 and perhaps the mileage is indeed low......look at the rotors, how much wear -are they badly grooved..... are the brake pads old or new looking......tell us something about the bike.....
Also look at the fork lower castings. Over 100K and they'll be chipped and show their age.
Daniel Meyer
Quote from: sandy on Fri 02, Aug 2013, 23:45:33
Not if you keep them covered in a protective layer of dirt! :)
CUAgain,
Daniel Meyer
Quote from: Daniel Meyer on Sat 03, Aug 2013, 14:11:54
LOL !
Its usually pretty easy for someone to try and falsify mileage. If there is an inspection sticker on the bike, there usually is a facility number on the sticker and maybe what the mileage the inspector thought was on the bike. This differs between states. But with the facility number at least you can find out the shops name and have a chat with them.Maybe the owner was a repeat customer. If the bike has changed hands before then maybe your DMV will still have the transfer records.
