Bright Bulbs for Speedo and tach
Started by Bronxboy, Thu 26, Jun 2014, 19:06:05
Previous topic - Next topic
Bronxboy
Does anyone have a link to the bright bulbs for the Valk Speedo & Tach? I seen them once before and they came in different colors?
DarkSideR
Quote from: Bronxboy on Thu 26, Jun 2014, 19:06:05
http://www.valkyrieforum.com/bbs/index.php/topic,34551.0.html
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
This has been a complaint for years.
The bulbs are a T 3 1/4 style.
The original is around a 2 to 2.5 CP [ Candle Power]
#161 is 2.7 CP
#158 is 3.3 CP  [ what I now use]
#194 is 3.8 CP
#168 is 4.9 CP [ said to hot and blisters ]
Many have switched to LEDs. Can't help you there.
GeoffreyB
Three months ago my tach bulb burned out and I went with the warm white x5 LED's mentioned in that thread.  LOVE THEM.  Good and bright, look close to original color of incandescent.
donaldcc
I liked the thread by chrise2469.  Anyone with a link to purchase the bulb he went with, the cool white X5?
Don
Just changed mine out to 194 bulbs, I went with the orange version since it matches the Motosen gauges I have.    Glad I did it.
Bonzo
Woops, I'm sorry.
Bronxboy
Bronxboy
Save this link, it has a bunch of great information.
http://www.jkozloski.com/generic_parts.htm
On the right column about 1/2 way down.
BobB
#10
I met Chris at Inzane XII and he demonstrated his LED instrument lighting.  I was very impressed, but mostly with the turn signal indicator.  I have had the nasty habit of failing to cancel turn signals.  But no more after installing his upgrade.  I also installed his LEDs in the instrument cans.
http://www.valkyrieforum.com/bbs/index.php/topic,35394.0.html
dan7uk
Does anyone have the part numbers for neutral, high beam and turn signal lamps that are brighter than OEM?
Woton
Quote from: Joshcornkid on Thu 26, Jun 2014, 19:16:13
Don't ride much at night, but I recently noticed my tach light has burned out.  The stock bulbs were always waaay to dim for my taste and I like the look of the cool white.  So, now's the chance...
Would someone make it easy for me... Is the cool white bulb in this series what I need to upgrade both speedo and tach illumination?
http://www.superbrightleds.com/moreinfo/wedge-bulbs/194-led-bulb-5-led-wide-angle-wedge-base/199/
"Ride Smart - Ride Safe"
