November 23, 2025, 04:03:28 PM *
Author Topic: Interstate gas tank  (Read 1019 times)
rknef777
Lake Martin, Al.
« on: June 30, 2015, 09:13:24 PM »
Hi guys,  hey got a question im sure someone has the answer too.  Ive been wanting to put a i/s. Tank on my tourer.  There is one on ebay that looks in good shape. I have the velcity stacks on mr carbs.
Just wondering if this will fit, if anyone with interstate has this combination. Only few hours left on item and would really like to do this but dont want to get rid of my stacks.  Put to much into them.  There leds
Inside that make it look like its firing.  Thanks in advance
« Reply #1 on: June 30, 2015, 10:23:08 PM »
I don't think, not 100% sure though,  the I/S tank will touch the velocity stacks, ONLY the side pods of the I/S have to be trimmed up some to get the stacks to fit and you don't have them on your std/tourer I assume.
I stand corrected, sorry, read postings below, but can be done with mods.
« Last Edit: June 30, 2015, 10:53:50 PM by cookiedough » Logged
« Reply #2 on: June 30, 2015, 10:32:25 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,3153.0.html
http://bigbf.com/bigbf_shop/custom_i-s_pod_v-stacks/
http://bigbf.com/bigbf_shop/how-to_install_v-stacks/
http://www.valkyrieriders.com/shoptalk/vstackspacermod.pdf
« Reply #3 on: July 01, 2015, 03:43:24 AM »
If you are doing the interstate tank because of extra gas I would suggest a belly tank that will answer increased mileage and you don't have to worry about the stacks. It gives you more range also than the interstate tank and you can have a regular fuel filter.
http://www.rmworksinc.com/Information.html
DIGGER
« Reply #4 on: July 01, 2015, 04:16:04 AM »
I have a stock 01 Tourerr (I put a tourer package on a 01 standard) and added the interstate tank.   love it.
« Reply #5 on: July 01, 2015, 04:29:18 AM »
It will work just fine. You need the spacer up front though. Easy peasy  cooldude
« Reply #6 on: July 01, 2015, 06:48:27 AM »
By all means go for it. Meathead is right, all you need is a spacer under the front mounting bolt to raise the tank enough to clear the forward stack. Works fine and a lot easier to install than a belly tank. With a good tune on the engine and the I/S tank, you can easily get well over 200 miles/tank.  cooldude
rhinor61
Northern California
« Reply #7 on: July 01, 2015, 07:25:37 AM »
Yes you need the spacer for the IS tank when using stacks..
+1 on the belly tank.
Pros:
3 gallons of extra fuel
eliminate the risk of hydro-lock
lowers the bikes center of gravity, especially nice as the level of fuel decreases.
No special jack adapter needed to lift the bike, just use a block of wood and 2 angle door stops.
Con:
Finding the person to properly solder the bung to the bottom of the tank.
I had purchased a IS tank, by time I got it painted to match the bike... its was a no brainer...
BELLY TANK all the way.
John
would I do it again
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
G-Man
White Plains, NY
« Reply #8 on: July 01, 2015, 10:04:46 AM »
You'll need the spacer as described above, but you will also need the plate to cover the whole for the gas gague thingy.
BigBF.com
Bill has everything you need!
« Reply #9 on: July 01, 2015, 10:28:15 AM »
BigBF.com
I think also adding a little rubber on the frames where the tank touches
MP
North Dakota
« Reply #10 on: July 01, 2015, 04:24:26 PM »
BigBF.com
Even better, get the is sender, and put a fuel gauge on. I did thid on my std. Love it. I think looks better with the bigger tank too.
"Ridin' with Cycho"
« Reply #11 on: July 01, 2015, 04:34:01 PM »
Go with both the I/S tank and then add a belly tank.    cooldude
You'll love the range of this set up.
