November 20, 2025, 09:03:17 PM *
Author Topic: Another New VRCC Vendor...  (Read 739 times)
« on: August 17, 2016, 03:50:28 PM »
As most of you know, DarkSider (Josh Chambers) has developed an adapter bracket to make the DayMaker LED headlight compatible with headlight assemblies of standards and tourers.
If you'd like a brighter light, check out DarkSider's adapter.
http://www.valkyrieforum.com/bbs/index.php/topic,89307.0.html
https://www.facebook.com/DayMakerBrackets/
« Last Edit: August 17, 2016, 04:02:08 PM by f6gal » Logged
« Reply #1 on: August 17, 2016, 03:56:26 PM »
Yep gonna do it  cooldude
big poppa pump
San Antonio, TX
« Reply #2 on: August 17, 2016, 03:59:58 PM »
Already did it !!
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #3 on: August 17, 2016, 04:03:01 PM »
How you like it?
Misfit
Colorado Springs Colorado
« Reply #4 on: August 17, 2016, 04:36:47 PM »
Welcome aboard Josh.  cooldude You should consider setting up a booth at Inzane 17 as a vendor.
DarkSideR
Pueblo, Colorado
« Reply #5 on: August 18, 2016, 06:18:08 AM »
Thank you, and am considering it. Since the installs do not take much time I could not only sell the Brackets and the DayMakers, but could also install them.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
« Reply #6 on: August 18, 2016, 06:33:11 AM »
Good job doing the legwork on these brackets, Josh.  This will be a good upgrade, and could potentially prevent some accidents.   cooldude
