November 23, 2025, 05:36:04 PM *
Author Topic: no light in tachometer  (Read 1622 times)
verngroves
Central New York
« on: January 14, 2012, 10:02:28 AM »
I've a 2000 Vakyrie Standard and there is no illumination on the tach. That makes for a challenge when riding at night. Is there any way to replace the bulb in that, or do I need to get a new tach in order to see the light again?
« Reply #1 on: January 14, 2012, 10:06:42 AM »
It's pretty easy.
You'll need to remove the screw at the back of the unit and pull the outer cover.  That should expose the socket holding the bulb.  Pull that socket out of its resting place, remove and replace the bulb and push the socket back into place.
« Reply #2 on: January 14, 2012, 02:58:34 PM »
Ditto what Willow said.  Easy to do.
However, while you're in there changing bulbs, you might wanna take a look at upgrading those bulbs to brighter, easier to see and read bulbs.  Here's some threads (with lots of pics) to read up on......
http://www.valkyrieforum.com/bbs/index.php/topic,32663.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,33054.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,33324.0.html
Kilroy
Clearwater, Florida / Overland Park, KS
« Reply #3 on: January 15, 2012, 07:23:26 PM »
Speaking about bulbs, is there a replacemen that would put out a little mor light for both the speedo and the tach?
"I was here, but now I'm gone"
chrise2469
Winnipeg Manitoba Canada
« Reply #4 on: January 15, 2012, 07:30:58 PM »
A very quick fix as willow said.  Here's two more links with lots of led info.  The tach uses a 194 wedge.
http://www.valkyrieforum.com/bbs/index.php/topic,34551.0.html
and a mod to allow led's in the turn indicators.
http://www.valkyrieforum.com/bbs/index.php/topic,35394.0.html
« Reply #5 on: January 15, 2012, 07:47:56 PM »
You didn't read my post......the one just above yours?
verngroves
Central New York
« Reply #6 on: January 20, 2012, 05:09:16 PM »
Thanks for all your info. When my garage is warmer....I"ll work on that light in the tach. This is a great site to get help for my Valkyrie from.    Cheesy
blackvalk
PARK CITY, UTAH
« Reply #7 on: January 23, 2012, 04:37:35 AM »
I installed the cool white x5 LED in the speedo/tach and LOVE the difference they made.
« Reply #8 on: January 23, 2012, 04:11:32 PM »
Just ordered x5 LED's. This was great string of posts! Thank you all!  cooldude
My rides:
