July 15, 2025, 07:52:17 AM *
Author Topic: Carb rebuild  (Read 963 times)
refuelman
Bartlesville Ok
« on: January 28, 2015, 01:48:58 PM »
I have a 99 Std with 60,000 miles and the rear carbs are starting to leak at the intake when setting. I have since starting sutting off fuel and running all fuel out of carbs. I know I will need to kit them, just wondering best place to get kits and should I rejet and also desmog?
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #1 on: January 28, 2015, 02:50:03 PM »
I would desmog. Less stuff on the engine. From where are the carbs leaking?
Have a safe ride
« Reply #2 on: January 28, 2015, 03:20:09 PM »
Do you mean at the base of the intake runner? If so you don't need carb work. Under the steel runners is an O ring. Our "Shop Talk" page has info for you. The O ring is a #123 and you should buy Viton material. One replace and that will be a forever fix.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #3 on: January 28, 2015, 04:25:47 PM »
You can get your carb rebuild kits from Red eye
http://redeye.ecrater.com/p/2063876/carburetor-gasket-kit-viton-gf
get your float valves from Amazon
http://www.amazon.com/Supply-Float-Needle-6pk-18-8955/dp/B001KOD732
refuelman
Bartlesville Ok
« Reply #4 on: January 28, 2015, 06:51:27 PM »
Yes, Sandy the fuel shows up at the base of the intake runner. I looked at the Shoptalk section and did not fine anything about the runners?
« Reply #5 on: January 28, 2015, 08:32:41 PM »
Don't touch your carbs until you replace the intake runner O rings. The redeyetech website sells the O rings . If you have a local hydraulic supply, ask for the #123 in viton. Very easy to change.
Savago
Brentwood - CA
« Reply #6 on: January 28, 2015, 09:38:51 PM »
Dear Friend
Seconding what other member said, check the photos on this thread:
http://www.valkyrieforum.com/bbs/index.php/topic,70101.0.html
Other photos in this thread:
http://www.valkyrieforum.com/bbs/index.php/topic,69409.0.html
If it looks similar, those are really good news: you can stop the leak by replacing the intake o-rings. I replaced mine about 3K miles ago and no leaks ever since.
It is a 2 hours job and the o-rings cost about 15 bucks.
Regards
Savago
« Last Edit: January 28, 2015, 09:42:13 PM by Savago » Logged
valknomad
North idaho
« Reply #7 on: January 28, 2015, 10:07:50 PM »
Note:  In the future, especially if rebuilding carbs,  I think it's good advice to do one thing at a time. (easier to retrace steps if something not running correctly).
Carb work and desmog may be problematic if you encounter a problem upon reassembly and start-up.
I know it's "tempting" to desmog while everything is apart..
refuelman
Bartlesville Ok
« Reply #8 on: January 29, 2015, 07:40:37 AM »
Ok thanks everyone. I will get right on replacing the O rings. Just another question on this, is it normal for that much fuel get in the runners while setting. Thank again.
