February 11, 2026, 05:46:18 AM *
Author Topic: Lighting!!  (Read 1525 times)
Gunner2
« on: November 04, 2015, 06:32:12 AM »
Since I can't seem to find what I'm searching for, I'll just start a new subject!  cooldude
Are there a different bulbs I can put into my tachometer and speedometer housings? Can I even get inside those things? When I ride at night, I can't see how fast I'm going.  Angry
Kep
My "Mid-life Crisis "
Indiana
« Reply #1 on: November 04, 2015, 07:28:49 AM »
I used the blue bulbs in mine..seem to be the most vivid for my eyes. Here is the link : http://www.valkyrieforum.com/bbs/index.php/topic,34551.0.html this is from a post that shows the indicator lamp upgrade , did this one too : http://www.valkyrieforum.com/bbs/index.php/topic,35394.0.html
« Last Edit: November 04, 2015, 07:30:20 AM by Kep » Logged
« Reply #2 on: November 04, 2015, 08:27:49 AM »
I've done both of these mods and I'm quite pleased with the results. I used blue bulbs for the tach and speedo. The brighter turn indicator now makes it easy to remebered to cancel your turns.  Roll Eyes
My rides:
Kep
Indiana
« Reply #3 on: November 04, 2015, 09:59:20 AM »
If you do the indicator upgrade , I would suggest that you only do the turn signal and Neutral bulbs ...if you switch to a brighter High beam indicator , it's wayyy too bright , especailly if you have a windshield. Creates too much glare back at you .
Paladin528
« Reply #4 on: November 04, 2015, 10:49:48 AM »
What about doing the same thing on an Interstate?
« Reply #5 on: November 04, 2015, 10:51:53 AM »
The original instrument [ tach/speedo] bulbs are about 2W [ can't remember the number, I think 159].
Replacements
158, 3.3W  [ work good]
161, 2.7W
194, 3.8W
168, 4.9W [ get too hot]
Joe Hummer
Arnold, MO
« Reply #6 on: November 04, 2015, 12:52:46 PM »
Here is a post I responded to with what I done...
http://www.valkyrieforum.com/bbs/index.php/topic,79604.0.html
Joe
1999 Valkyrie Interstate
Mtn Valk
North Ga.
« Reply #7 on: November 05, 2015, 06:58:11 AM »
Gunner2 also asked: "Can I even get inside those things?" (the tach & speedo)
J3
« Reply #8 on: November 05, 2015, 08:51:35 AM »
Really didn't think that needed to be answered. Its easy, just remove the cover and replace the bulbs. The reset knob needs to be removed on the speedo, allen wrench if I remember.
Mtn Valk
North Ga.
« Reply #9 on: November 05, 2015, 10:07:28 AM »
Thanks for explaining that without losing it, as some do here.... (even though it would have done me a lot of good to "take a look" 1st!
J3
« Reply #10 on: November 05, 2015, 12:30:57 PM »
No problem. Hope it helps. If the speedo reset doesn't have an allen screw [ I think it is] then it could be a small screw [ JIS].
« Reply #11 on: November 05, 2015, 05:18:34 PM »
Mine was a small Phillips headed screw. Don't loose it!  Roll Eyes
My rides:
« Reply #12 on: November 06, 2015, 03:28:46 AM »
Is it a JIS phillips ?  OK, good, its been a long time since I've had it off.
cogsman
Newmarket, Ontario, Canada
« Reply #13 on: November 06, 2015, 05:17:08 PM »
So here is the blue bulb spoken of above:
https://www.superbrightleds.com/moreinfo/194-led-bulb-1-smd-led-miniature-wedge-retrofit-car/204/908/#/tab/Specifications
At the current Canadian-US exchange, this is going to cost me over $30 CAD to get these bulbs!
I went onto eBay and amazon, and I am seeing a lot of very reasonably priced 194 LED Blue bulbs, but they seem to be a different spec... 6 SMD vs 1 SMD (whatever the heck that means anyway), and they tend to be T10 instead of T3-1/4 as specified in the link above...
Here is an example of blue 10 pack for $7 CAD shipped... but would they work? :
http://www.amazon.ca/Blue-5-SMD-5050-Wedge-Light/dp/B00GYW3JRO/ref=sr_1_3?s=automotive&ie=UTF8&qid=1446860167&sr=1-3&keywords=194+led+blue
fordmano
San Jose, CA.
« Reply #14 on: November 07, 2015, 01:58:06 AM »
Here is a thread that has a bit of info for the I/S dash-panel lights,,,,,,,, Well I chimed in there and you can see some of my pictures with how it looks with what i installed.
http://www.valkyrieforum.com/bbs/index.php/topic,50996.0.html
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #15 on: November 07, 2015, 03:34:33 AM »
Can't help with those LEDs. But, if ones are found to work, then I would think heat wouldn't be an issue.
